My dash has gone CRAZY
Old Jan 23, 2012 | 10:42 AM
oh3monteSS's Avatar
Exclamation My dash has gone CRAZY
Hey Everyone. So my dash has gone Crazy The ABS, E-Brake, Trac Off and the "Service Traction Soon" Light is on in the Info center, But that is the only messages that goes away after about 3 minutes of driving. My check engine light is on from when I replaced my catalytic converter. I replaced both O2 sensors and it still won't go away :\ Anyone have any info on my ABS issues?
Old Jan 23, 2012 | 10:59 AM
CEL light because of Cat is probably because the replacement isn't the exact same spec as OEM. These cars are very picky, and you won't get that CEL to shut-off without tuning the P0420 code out of the PCM.
Check your Brake Fluid Level, that can affect the BRAKE light. A wheel hub assembly/sensor can trip the other lights.
If all of those things check out, you might be getting some electrical gremlin that is harder to track down.
Old Jan 23, 2012 | 11:27 AM
There may be one alternative to stopping the P0420. Look up a trick using a "Spark Plug Non-Fouler". Basically, you space the rear O2 sensor out of the exhaust stream. I read a LOT of people claim success with that trick on all kinds of makes/models. If all you were doing was getting a tune to rid that code, I'd explore that trick first.
mwjames
Dec 25, 2013 08:27 PM
Denzell Rodgers
Sep 16, 2013 08:13 AM
Aug 12, 2012 09:27 AM
Pretty00Pace
Feb 18, 2011 10:02 PM
montego
Apr 13, 2010 04:30 PM
