03 monte is missimg and has no power.
I have an 03 monte ss and it has lost all power. Can't gain any speed at all. As I give i gas
it falls off. Run perfect in neutral. I changed the plugs fuel filter and maf censer and it hasent changed. If I unplug the maf censer it runs perfect. Any ideas?
I thought if the cat is restricted that unplugging the MAF sensor would make no difference in the way the car runs.
I would test and clean the MAF sensor to see if it makes a difference in the way the car runs before replacing the cat.
87montels305
Feb 23, 2006 01:47 AM
