03 monte is missimg and has no power.
Old Jun 1, 2012 | 06:23 PM
dillon_4's Avatar
Default 03 monte is missimg and has no power.
I have an 03 monte ss and it has lost all power. Can't gain any speed at all. As I give i gas
it falls off. Run perfect in neutral. I changed the plugs fuel filter and maf censer and it hasent changed. If I unplug the maf censer it runs perfect. Any ideas?
Old Jun 1, 2012 | 07:28 PM
aussiek2000's Avatar
plugged converter.
Old Jun 1, 2012 | 07:38 PM
Franks 03SS's Avatar
2011 Monte Of The Year
Clogged cat! Lol
Old Jun 2, 2012 | 10:12 PM
dillon_4's Avatar
Thanks guys. Is there a way to unclog it or do I have to replace it?
Old Jun 3, 2012 | 06:29 AM
Your only options are to gut it, run a pipe through it, remove it, or replace it. The first 3 will cause a CEL.
Old Jun 3, 2012 | 06:52 AM
03SSLE's Avatar
Originally Posted by aussiek2000
plugged converter.
Clogged cat! Lol
I thought if the cat is restricted that unplugging the MAF sensor would make no difference in the way the car runs. I would test and clean the MAF sensor to see if it makes a difference in the way the car runs before replacing the cat.
Old Jun 3, 2012 | 09:58 AM
dillon_4's Avatar
I replaced the maf and it didn't fix the problem I'm stumped.
Old Jun 3, 2012 | 11:01 AM
Enzo354's Avatar
STILL SLOW
Then replace the cat.
Adam Metz
Nov 14, 2013 12:47 PM
Adam Metz
Nov 8, 2013 07:09 AM
GMfever
Apr 25, 2013 04:53 PM
catchk9
Nov 14, 2012 07:45 PM
87montels305
Feb 23, 2006 01:47 AM
