Opinion Needed: 01 3.4 LS MC Stalling & sputtering while idle
Old Apr 4, 2015 | 03:07 PM
SpartanDawgs's Avatar
Default 01 3.4 LS MC Stalling & sputtering while idle
Hey everyone, I've been a long-time lurker on this forum, but only today decided to sign up because I couldn't find an answer to this particular question.
Yesterday while driving, my car stalled 5-6 times. It was always when I was either idling at a light, or turning (i.e. going very slow). I was always able to turn the car right back on, until I was at another stop. The thing is, it isn't producing any codes. From what I've read, it could be a large number of potential things, but they seem to always produce codes. So, I wasn't sure where I should begin. I haven't had a tune-up since about October, though I haven't driven much through the Midwest winter.
I'm really busy this weekend, as some of you may be as well with the holiday, so I will get around to checking out air filter and MAF tomorrow evening if I can.
Thanks for the help and happy almost Easter!
Old Apr 4, 2015 | 06:44 PM
03SSLE's Avatar
Check for vacuum leak(s).
Old Apr 4, 2015 | 07:07 PM
There are lots of things that can cause this. My first thought is checking the maintenance history. If the spark plugs have over 100K miles on them, I would advise replacing them (the plugs used from the factory are good for 100K, 150K max, but after 100K, they could be worn and not giving a good spark, low speed/low RPM and it's just not enough to keep it going).
AsTheDaysOfNoahWere
Dec 23, 2024 09:24 AM
85v6
Oct 6, 2020 11:16 AM
Jamie
16
Jul 18, 2011 07:42 PM
ajsbengals
Apr 12, 2008 09:51 PM
Top_Notch
Feb 6, 2007 09:10 PM
