Opinion Needed: 00-05 Monte dashboard twist off lights
Old Jun 2, 2014 | 10:33 AM
NOFTY's Avatar
Default 00-05 Monte dashboard twist off lights
Okay I have a 2002 LS Monte Carlo that I was looking to do a gague cluster swap from LS to the SS with the oil gague and volt read out for looks due to no oil pressure sender. But heres my question which years of the SS had the twist off bulbs in the gague cluster because I pulled a gague cluster off a 2000 SS that was wrecked and found that the lights were soltered in and I already purchased the LEDs for the twsit ins.
Old Jun 2, 2014 | 11:06 AM
All 2000+ clusters use soldier in bulbs.
There currently is no known easy way to make the oil pressure readout work. I recommended a member doing that swap switch out the connector and the oil pressure sending unit. Still did not work. I speculate there is a hidden setting in the PCM for it.
Radagast the White
Nov 23, 2013 02:36 PM
spiknek
May 9, 2011 11:57 PM
cjbots
Jan 20, 2011 12:30 AM
96MonteCarloZ34
Jul 29, 2010 05:30 PM
knightfan26917
Jan 8, 2008 04:29 PM
