Key cylinder install
From all the videos I have seen, people are removing the front dash panel in order to get to the key lock cylinder. Is it easier just to move the radio out of the way in order to gain access to the key lock tab to remove the cylinder?
I assume this is a 2000 or newer Monte? If so, to do anything with the radio, you have to pull the dash piece anyways. And I'm trying to remember, I think you have to pull the cluster out too. None of it is a big deal, the key is take your time.
Repair Guide: Removing ignition lock cylinder without the key
The_Maniac
FWD Tech Guides '95-'07
03-20-2021 08:41 PM
Repair Guide: Key cylinder install made easier...pics
excaliburken
08-28-2018 08:51 PM
Kenny Guido Temprano
07-16-2017 10:51 AM
