Problem with A/C system
Old Jun 12, 2012 | 11:07 PM
suburbiangiant's Avatar
Default Problem with A/C system
Hi guys, I have a 2002 Monte carlo SS and the drivers side air conditioning is blowing warm compared to the passenger side. I'm assuming the blend door is faulty or not closing completely or the climate control slider is bad. Has any one else run into this issue? How difficult is this to repair?
Regards,
Mike
Old Jun 13, 2012 | 08:28 AM
You could also have a slight leak in the AC and freon is getting low.
Old Jun 13, 2012 | 09:57 AM
The passenger side is cold so I know it's not a freon problem since it's a single system.
Old Jun 13, 2012 | 11:44 AM
The driver's side can be warmer when the freon is low.
It could also be the blend door, I'm just letting you know before you do the work if you want to just get the system checked
Old Jul 15, 2022 | 12:31 PM
Jeffyd's Avatar
Regards,
Mike
A/C problem
I have the same problem. Cold air only from the passenger side vents. And not always.??
The compressor is working (motor undulates)
Old Jul 15, 2022 | 02:52 PM
Originally Posted by Jeffyd
A/C problem
This thread was last used in 2012. Many of the people have not been back on this site in years. I would suggest starting a new thread about your issues and have active members chime in.
Old Aug 26, 2022 | 03:37 PM
Frenchwg's Avatar
This may be an old thread -- but some of the old responses have sure helped me.
For me, the difference between the diriver and passenger side temps was due to low freon. Had leak fixed and refilled --- working great since.
twk114
Dec 29, 2011 01:12 AM
augi
Mar 21, 2011 09:29 AM
MonteLSV6
Jan 30, 2010 04:20 PM
Cloud_Master
Mar 25, 2008 11:25 PM
Mike95MonteLS
Sep 25, 2006 01:36 PM
