Traction system problem
Old Jan 17, 2010 | 04:58 PM
MonteLSV6's Avatar
Default Traction system problem
After getting my car back a week ago from the shop after replacing a intake manifold gasket, soon after did my "Service Traction System" light pop on in the message center along with the "((ABS))" and "TCS" (the light that comes on when you push the traction button) light in the gauge cluster. About 5mins later the "Service Traction System" light in the message center will go away but then the two lights in the gauge cluster will stay on till i shut my car off. Long story short, I went to Autozone and they said it was the VSS (vehicle speed sensor) which is unfortunately located in the wheel hub. Is their any way i can tell which wheel hub it is?
Old Jan 17, 2010 | 05:59 PM
Wilco's Avatar
The VSS isn't located on the hub but on the passenger side's transaxle. It's held there by one bolt and it's pretty easy to get to. BTW, change the O ring with a new one when you do change it. You should check it first before you replace it to make sure the VSS is defective. The sensor only has 2 wires so it isn't to hard to check but you'll probably need someone to rotate the right front side tire for the test. Do not disconnect the sensor. Using a voltmeter, connect the leads to the 2 connector's wires, set the VM to AC volts scale, turn the ignition key to the ON position and have someone turn the front right tire (by hand) while you watch the VM. The sensor should produce a minimum of .5 volts and the voltage should increase as the transaxle output shaft rotates faster. Turn the ignition key OFF and disconnect the electrical connector from the sensor. Using an ohmmeter, measure the resistance across the 2 terminals of the sensor. The sensor resistance should be between 1500 and 1650 ohms at 68*F. (If the test results are incorrect, have the VSS checked by a dealer service department)
A defective VSS can cause driveability and transaxle problems, as well as speedometer misreadings.
Old Jan 18, 2010 | 09:36 AM
If it's a hub you would need a diagnostics reader to read the ABS codes (autozone can't read those)
Old Jan 18, 2010 | 10:30 AM
wiz kidd's Avatar
it will be the abs sensor on the hub that is causing the problem, and i dont think there's a way to easily tell which one it is, you'll just have to try them 1 @ a time
Old Jan 18, 2010 | 11:40 AM
Wilco's Avatar
The hub sensor connectors can get dirty causing bad signal readings and thus setting off the STS light. You could try cleaning them with an electrical cleaning spray, available at radio shack, to remove the offending dirt. You may want to check for damage to the wires/connectors by following the wiring to the hub sensors.
Old Jan 18, 2010 | 03:01 PM
MonteLSV6's Avatar
That's what the guy said at the shop after I got my car back chichiblacksheep. Is their a store that can read the code? The guy at Autozone said that it was the hub....or that its in the hub...so should I just check the sensors then and clean them up montyss02?
Old Jan 18, 2010 | 04:04 PM
Wilco's Avatar
For starters, I'd clean them as good as possible and check the wiring for damage. As far as the diagnostic reader, you may have to go to the dealer un less you can find someone that will do it for you at a reasonable price. It doesn't hurt to call around and check the neighborhood mechanics to see if anyone can read your car.
Old Jan 18, 2010 | 04:28 PM
RocknSS04's Avatar
And why is this in the A/V sub-forum?
Old Jan 19, 2010 | 12:55 AM
MonteLSV6's Avatar
well it is part of "Audio/Visual Electronics" if you really think about it haha...couldnt decide on another place for it
Old Jan 19, 2010 | 08:49 AM
It's in the General Tech section.. IDK what you mean :P
