new system
Old Jun 22, 2008 | 04:19 PM
xxprebunkxx's Avatar
Default new system
Hey guys I just got a new system put in my 02 Monte. 6x9 Alpines in the back, 6 1/2"s in the door, 10" kicker solo-baric with a 500 watt RMS sub in the back. I'm gonna be adding a 4 channel amp, 50 watts RMS x 4 for the interior speakers. I was wondering if I'm going to have to upgrade the battery or the alternator? Thanks in advance.
Old Jun 22, 2008 | 04:57 PM
mrl390's Avatar
Default RE: new system
I dont have muchexperience with sound systems, but I have seen much more powerful systems running on stock alternator and battery so I think you will be fine.
Old Jun 23, 2008 | 07:05 PM
paddock's Avatar
You should be fine with the stock battery and alternator..
Worse case scenario, you may want to upgrade the battery to a good Optima. If you are going big watts, a stiffening capacitor might be a good idea!
Old Jun 23, 2008 | 07:48 PM
Thanks for the input guys! Much appreciated.
Old Jun 23, 2008 | 07:55 PM
sickofsoyo's Avatar
I have approximately 2000 watts drawn at MAX, 1600 RMS, for a single amp, and I dont have TOO much of a problem stock. I need to get some upgrades though, I have some light dim, and voltage droops, and NO, CAPACITORS DO NOT FIX THE PROBLEM.
Old Jun 24, 2008 | 12:08 PM
mavrickf1613's Avatar
Monte Of The Month -- January 2009
DEFINATELY GET A YELLOW TOP OR RED TOP OPTIMA, I HAD MY RED TOP OPTIMA BATTERY RUNNING A STEREO SYSTEM FOR 3 YEARS AND THE BATTERY LASTED 6 YEARS. THE OPTIMA BATTERY IS A $100 TO $150 BUT ITS WORTH IT. DO YOU HACE A CAPACITOR TO YOUR AMP? IF YOUR LIGHTS DIM AT NIGHT THEN YOU WILL NEED A CAPACITOR FOR YOUR AMPS.
YOU DON'T NEED TO WORRY ABOUT THE ALTENATOR WITH A OPTIMA BATTERY AND A CAPACITOR.
COOL SYSTEM
milrlyt
Feb 23, 2011 02:04 PM
RocknSS04
26
Jun 28, 2009 08:07 AM
RocknSS04
May 7, 2008 04:28 PM
JayTee716
Apr 6, 2006 02:32 PM
montejass
Mar 29, 2005 01:16 PM
