HID"s
Old Mar 10, 2012 | 10:11 PM
  #51
MONTE2000SS's Avatar
so he has high beam kit right...cause in one pic his drls are on sorry to be a pain just want to make sure i get the right thing ...and the for fog light i just put the 880 in and the same color of the hids in headlights right????
Old Mar 11, 2012 | 12:48 AM
  #52
He did do the highs, which I don't recommend, if I were you I would do the 9006 bulb which is the low beam and 880 bulb which will be the fogs, you'll see that you don't really have a need for high beams anymore with HIDs
Old Mar 11, 2012 | 01:10 AM
  #53
i am thinking the 8000k from ddm what one did you get i want to be alittle blue but not real blue but still want to notice the blue..if that make any since and what fuse do i have to pull to disable drls??
Old Mar 11, 2012 | 01:20 AM
  #54
I have 8000k but they have since changed their bulbs, you should still be good with 8000k tho, if you're not getting high beams you wont have to disable the drls but if you do get high beams then the there should be a drl relay i believe
Old Mar 11, 2012 | 01:29 AM
  #55
well i dont want them running when it starts to be dusk cause i like to run just park lights and fogs will i be able to do that if it s not to dark out
Old Mar 11, 2012 | 01:32 AM
  #56
I'm not a 100% sure how the fogs work on the SS models because I have mine custom wired, but don't they only come on with the low beams?
You could always run the DRL wire to the fogs so that the fogs come on anytime the DRLs would, but then you would have to figure out how to wire them so that they could also run with the low beams
Old Mar 11, 2012 | 03:01 AM
  #57
no theres a push button but ill keep ya posted when i get them ..thanks for the help..im sure ill run in to something on install but well see if plug in play is plug and play
Old Mar 11, 2012 | 11:05 AM
  #58
just ordered 8000k for headlights and 8000k for fog from ddm tuning
Old Mar 11, 2012 | 11:50 AM
  #59
But it runs off a relay so that the fogs don't go on while the high beams are on, which is why I'm not sure if they'd go on with the DRLs, if that makes sense..
Awesome!
MJClemm
Oct 26, 2012 05:56 PM
milrlyt
Feb 4, 2012 07:14 AM
knightfan26917
Nov 27, 2011 01:31 PM
86 luxury sport
Jun 6, 2011 02:41 AM
brandonmac000
19
Apr 9, 2011 09:54 PM
