Key cylinder install
Old 08-22-2018, 12:04 PM
excaliburken's Avatar
Default Key cylinder install
From all the videos I have seen, people are removing the front dash panel in order to get to the key lock cylinder. Is it easier just to move the radio out of the way in order to gain access to the key lock tab to remove the cylinder?
Old 08-22-2018, 05:10 PM
Popping off the dash panel is pretty easy, I'm not sure if you can get to the 2 bolts by pulling the radio out. If you find it easier that way maybe you can take some pictures for the group. Good luck.
Old 08-24-2018, 11:04 PM
I assume this is a 2000 or newer Monte? If so, to do anything with the radio, you have to pull the dash piece anyways. And I'm trying to remember, I think you have to pull the cluster out too. None of it is a big deal, the key is take your time.
The_Maniac
FWD Tech Guides '95-'07
03-20-2021 08:41 PM
excaliburken
08-28-2018 08:51 PM
Kenny Guido Temprano
07-16-2017 10:51 AM
71malibu
05-03-2015 09:13 PM
Frank_Tha_Tank
04-30-2010 08:49 PM
Quick Reply: Key cylinder install
