Help with new Radio wire please!!!!
Old Jul 23, 2007 | 07:54 PM
Monte_04's Avatar
Default Help with new Radio wire please!!!!
I just bought a relocation harness for an '04and i have it all set but what to do about the red wire so
what i need to know is what wire i can use to splice the 12v (red wire) wire to, so that it will turn on and off like it should so if any one had to do this please let me know what to do.
Old Jul 23, 2007 | 10:36 PM
HyperFox's Avatar
Default RE: Help with new Radio wire please!!!!
This all depends on where you intend to relocate the factory deck to. What you need to do is skeetch a test light(or preferrably a multimeter) and probe the connectors close to where you are going to relocate the factory deck. You will need to find a 12V constant, and a 12v that only turns hot when the key is in ACC and ON.
Another way is too run another splice from the aftermartkets harness to the factory deck, and I would DEFINITALLY encorporate a 12v fast blow fuse in both lines to prevent overdraw. Do not upgrade the stock fuse, as the fuse is rated for the load of the radio. If the factory fuse blows out, you will know that you are shorting, or exceeding the load limit of the factory wiring. Use only the same guage wire for the extensions as the factory harness. To small of a wire, and it might burn up from the load, too big, and your just wasting cash.
Good luck to you!
Old Jul 24, 2007 | 06:20 AM
Monte_04's Avatar
I have used a test light and cant seem to find a wired that will turn hot when i turn the key on and off when i turn it off. I was thinking someone might have done something like this and can tell me what wire they have used.
Old Jul 24, 2007 | 06:40 AM
Hi Ray,
Use the MCF Search to explore, or click the below link
and see `if it helps you. Be patience, and I'm sure a member
that has the answer will post 4 U.
Good Luck, `Space
Old Jul 27, 2007 | 09:57 PM
BloodAndHonor's Avatar
i put mine in with a fuse in my fuse box, works good u put it in your glove box. fits well too.
blueacres
Nov 1, 2013 05:20 PM
owens91
Dec 13, 2012 02:08 AM
Murray137
Oct 20, 2012 08:13 PM
SS02
Aug 8, 2012 12:03 PM
Josh_NGR
Mar 21, 2012 08:56 PM
