Hard wire LED Help please!!!
Old Nov 1, 2013 | 03:18 PM
blueacres's Avatar
Default Hard wire LED Help please!!!
I just got 2 small led strips and I want to have them on whenever the car is running so i wrapped one end to a constant fuse and grounded the other. When I started up the car the lights were super dim, you could barely see them. What could be the problem not enough power or something? I merged it to the 10 Amp radio fuse.
Old Nov 1, 2013 | 05:20 PM
dbaldwin's Avatar
You got LED strips without a control box? just cause its a ten amp fuse doesn't mean it putting out ten amps. What is the recommended voltage and wattage for the LED strip (wattage is P=IxE, P=wattage, I=current [in amps] E=Voltage) If its dim your probably running the wrong Amperage through the LED strips. Could also have a bad ground. check the suggested rating on something before you just plug it in. could also be a cheaply doped LED's are they SMD LED's or standard?
KingOf206
Dec 25, 2013 07:12 AM
Murray137
Oct 20, 2012 08:13 PM
gkathleenw
Feb 29, 2012 11:03 AM
tom272
Feb 16, 2012 11:01 AM
