Dome Light
Old Apr 2, 2008 | 10:08 AM
Mitchum5543's Avatar
Default Dome Light
hey all I am wanting to replace my Dome light with an LED but the first problem I run into is how the hell do I get the cover off to even get to the housing it self please help and thank you
Old Apr 2, 2008 | 11:37 AM
mickey's Avatar
Default RE: Dome Light
I used a small screw driver that i wraped the end with some tape so i didnt scratch things up.
but if you look straight up on it you will see a small area that you can get something in there to pry the lens out. and belive me it is not fun you think your goign to snap it in half. but it will flex slightly so tha tyou can get it out of there. then it will just snap in agian.
same wiht the map lights.
the ones under the dash in the 6th GEns are a 194 same as the map lights.
Old Apr 5, 2008 | 08:37 PM
so basiclly is just gettin like a flat head inbetween the lens and the actual housing the whole it self dosent come apart ? just the lens should snap out and give me access to the bulbs correct ?
Old Apr 5, 2008 | 09:37 PM
mickey's Avatar
yep pretty much
GooberMT
Jul 4, 2007 02:53 AM
Monte_04
Feb 28, 2007 05:03 PM
Monte_04
Feb 26, 2007 09:32 PM
01BlkSS
Dec 25, 2006 04:18 PM
big green dog
Jul 7, 2006 02:12 PM
