6th Gen ('00-'05): Aftermarket Head Unit & Quiet Sound
Old Dec 22, 2012 | 11:04 PM
Weez's Avatar
Default Aftermarket Head Unit & Quiet Sound
2001 Monte LS with factory amp in rear shelf
Sony BT4100P Head Unit
Metra Axxess GMOS 04 Wiring Kit
I have very little sound - its very quiet and stereo maxes out at 50 and to be able to hear anything while driving I have the stereo at 45, any higher and its just garbled mess. At 45 I feel like its a whisper.
All Fixed:
The Metra GMOS-04 is the right adapter for Monte Carlo's with the factory amplifier under the rear package tray in the trunk. These sell for anywhere from $60 - $100, If you buy a Receiver from Crutchfield they sell it for $50.
The Metra has TWO red power wires, Hook them both up!
The Metra has a blue/white remote amp turn on lead - Hook it up!
The Metra adapter has a small screw that increases the volume of the door chime - it is like a gain ****, turn it up or down - your choice on wheat level of sound and door chimes you want.
The Metra has a bunch of extra wires as its a universal adapter - tape up the open wires.
Old Dec 24, 2012 | 03:30 PM
owens91's Avatar
is that the only adapter that works with the monte carlo? ive tried a few harnesses and it dont fit the 3 connectors at all. and where did you get yours from and for how much?
Old Dec 24, 2012 | 03:35 PM
fiveirontimmy's Avatar
I have an 07 with that amp under the rear deck. For mine there was a harness made by PAC and you just had to either plug into the non-amplified or amplified port. Is yours something similar to this?
Old Dec 24, 2012 | 10:16 PM
Weez's Avatar
I'm using the Metra Axxess GMOS 01 which installed the Sony stereo to all the factory connectors.
I bought my stereo through Crutchfield (free shipping, no sales tax, free antenna adapter, free mounting kit, instructions/how-to guide, $25 gift card) and paid $50 for the GMOS 01.
I would like to fix the lack of sound - pretty sure I need to bypass the factory amplifier in the trunk - it makes sense as the Sony receiver is most likely more powerful & better sounding than the 12yr old factory amp.
Will the Metra 70-2054 fit? -
This post says to use the Metra 70-2021 - https://montecarloforum.com/forum/in...ing-amp-33478/
Anyone with experience using is - what kind of wiring do I still need to do after installing it?
Amazon has great review for Monte Carlos using the Metra 70-2021 - http://www.amazon.com/Metra-Amplifie...DateDescending
Old Dec 24, 2012 | 11:27 PM
owens91's Avatar
ugh crutchfireld wants 190 for that adapter so is this for sure the only way i ca get a aftermarket radio? and i do also have the stock amplifier in the trunk
Old Dec 25, 2012 | 03:59 PM
My PAC was like, $70 from amazon, or about $150 at a car audio shop. For a while I was running the factory head unit through the factory amp through a JL audio cleansweep to my aftermarket amps... best sound I've ever heard out of a factory headunit and unless you knew what was in there, you had no idea til you cranked it
Old Dec 25, 2012 | 04:10 PM
iMSeRiOuS's Avatar
I had a similar problem..
in the settings for my stereo I had an EQ built in... so I just boosted the vocal freqs... You'll find this on higher end stereos like a kenwood exelon or some of the nicer alpines
Old Jan 3, 2013 | 10:10 PM
Weez's Avatar
All Fixed:
Old Jul 24, 2014 | 08:59 AM
I have since replaced my aftermarket deck with the factory unit and installed the JL Audio Clean Sweep line processor on the output from the amp under the rear deck. When I tell you this thing sounds way better (minus a little hiss on certain inputs/at low volume) than just about any deck I've ever owned, I'm not lying. JL Audio is a little pricey (not so bad on the internet) but you get exactly what you pay for.
Habbibie
Jun 27, 2013 01:09 PM
irace88
Jul 14, 2011 05:07 PM
Randdady
46
Apr 9, 2011 02:51 PM
04MonteLS
15
Aug 26, 2009 05:41 PM
04MonteLS
31
Apr 3, 2006 01:44 PM
