6x9 Question
Old Jul 5, 2011 | 09:46 PM
MoGs LS4's Avatar
Default 6x9 Question
just got new infinity 6x9's for my 06 ss, but with the factory amp i noticed there is harnesses connecting the stock speakers to the amp do i need to buy special harnesses for the new speakers or can i just hard wire them to the amp?
any suggestions.......
Old Jul 6, 2011 | 12:52 PM
sfritz85's Avatar
Good Question!... I have an 02 with a factory amp under the rear deck... I too want to upgrade my 6x9's...
I will have to check for this...I only looked at the connections on the speakers. I will check and get back to you... For grins I wonder if your amp is similar to mine?
Old Jul 6, 2011 | 06:18 PM
walkingonabullet's Avatar
you should be able to hardwire them but the stock speakers are 2 ohms, those... accualy nmight be 2 ohms, i think allot of infinitys lower end stuff is 2 ohm. so if they are, you should be golden. find that out before you hard wire them up.
Old Jul 6, 2011 | 07:27 PM
mcdave01's Avatar
correct you can hardwire them to the speakers. also most of infinity's products are 2 ohm speakers because they have "true 4 ohm" technology. they claim that making the speaker 2 ohms that due to the factory wiring being a smaller gauge creating resistance that the actual impendence seen by an amp/head unit is closer to 4 ohms. but as far as installing those infinity's, i dont know which ones you have exactly but regardless, i would recommend matching an amp to those giving them the power (maybe a little extra :P) that they need. i have infinity kappa 6.5" coaxials in the front with jbl gto 6x9's in the back with an alpine pdx-f4 and boy it sure cranks, without sacrificing sound quality.
Old Jul 6, 2011 | 09:45 PM
MoGs LS4's Avatar
i have the 693.9i speakers, i was thinking i would have to get a new amp...
anybody have any suggestions or links they can send me for amps...?
06LT3
FWD Tech Guides '95-'07
19
Nov 29, 2010 05:16 AM
Bxbootlegger
Feb 14, 2008 08:34 PM
86Ls
Jan 1, 2008 05:23 PM
rrobert05
Apr 5, 2007 10:19 PM
04MonteLS
Jun 7, 2005 12:59 AM
