6x9 Question
just got new infinity 6x9's for my 06 ss, but with the factory amp i noticed there is harnesses connecting the stock speakers to the amp do i need to buy special harnesses for the new speakers or can i just hard wire them to the amp?
any suggestions....... |
Good Question!... I have an 02 with a factory amp under the rear deck... I too want to upgrade my 6x9's...
I will have to check for this...I only looked at the connections on the speakers. I will check and get back to you... For grins I wonder if your amp is similar to mine? |
you should be able to hardwire them but the stock speakers are 2 ohms, those... accualy nmight be 2 ohms, i think allot of infinitys lower end stuff is 2 ohm. so if they are, you should be golden. find that out before you hard wire them up.
Originally Posted by walkingonabullet
(Post 340346)
Originally Posted by mcdave01
(Post 340353)
correct you can hardwire them to the speakers. also most of infinity's products are 2 ohm speakers because they have "true 4 ohm" technology. they claim that making the speaker 2 ohms that due to the factory wiring being a smaller gauge creating resistance that the actual impendence seen by an amp/head unit is closer to 4 ohms. but as far as installing those infinity's, i dont know which ones you have exactly but regardless, i would recommend matching an amp to those giving them the power (maybe a little extra :P) that they need. i have infinity kappa 6.5" coaxials in the front with jbl gto 6x9's in the back with an alpine pdx-f4 and boy it sure cranks, without sacrificing sound quality.
anybody have any suggestions or links they can send me for amps...? |
