2003 Monte Carlo Crackling/Distortion with GM0S-04
Old Aug 5, 2011 | 07:36 AM
Lthorn14's Avatar
I am going to hook it up with my factory headunit at first since its plug in play. If Im not satisfied with the sound then I'll install the aftermarket hu.
Old Aug 5, 2011 | 01:36 PM
Milhouse's Avatar
I rest my case
Old Aug 5, 2011 | 04:11 PM
Lthorn14's Avatar
Originally Posted by Milhouse
I rest my case
Everything hooked up with factory head unit and it sounds amazing for just one 10" sub! Would the aftermarket headunit increase performance much? I just don't see the reason to go cutting wires without better performance. I have read that most people have to bypass their factory amps when adding new headunits because of bad quality, is that true?
Old Aug 5, 2011 | 08:37 PM
Milhouse's Avatar
It would, because right now you're introducing inefficiencies into the system due to having to have the LOC convert a high level output to a low level output and the input signal the LOC is getting is already low without the conversion. Aftermarket deck would give you a stronger signal to the amp without the conversion which will result in better SQ and better response.
Old Aug 6, 2011 | 10:01 AM
Lthorn14's Avatar
Thanks for the help Milhouse, i'm sorry if im coming off as stubborn i'm just trying to fully understand and I am noob when it comes to car audio.
So to hookup my aftermarket hu I would just have to cut the plug off that connects to my stock hu then splice the wires? Then would I plug my RCA's into the AOEM-GM24 or just the back of my aftermarket hu?
Old Aug 6, 2011 | 06:30 PM
Milhouse's Avatar
No, you wouldn't cut the factory plug, that's asking for it. You'd need to buy a harness that plugs into that plug and gives you the wires you'd need to connect your factory deck to it. Costs about $50 and is worth every penny!
Old Aug 7, 2011 | 12:29 AM
Lthorn14's Avatar
I didnt mean cut the factory plug im not that big of a noob! I meant could i cut the plug on the AOEM-GM24 harness. I dont understand why I need a harness since i already have one. What harness would you suggest anyway? I refuse to use the gmos-04 because of bad reviews and bad personal experience.
Old Aug 7, 2011 | 02:10 AM
Milhouse's Avatar
I don't understand why you'd cut any plug??? I'm not familiar with that harness you're talking about so I can't call it.
Old Aug 15, 2011 | 07:50 PM
Lthorn14's Avatar
Oh you aren't familiar with the harness, that's why you thought I was getting crappy sound quality. The harness isn't a simple LOC and is supposed to get the pure clean untouched signal right from the head unit. You should look it up "AOEM-GM24". After doing all kinds off research I've decided I won't replace my headunit until I replace everything else at the same time.
DenaliZO6
13
Feb 25, 2012 10:01 PM
milrlyt
Feb 28, 2011 11:25 AM
Wattz05
Jul 20, 2009 03:25 PM
XM_JDM
Feb 3, 2009 10:20 AM
kweef
Apr 20, 2008 09:43 PM
