Whistling Noise
Old May 25, 2010 | 08:55 PM
MrMcknight's Avatar
Default Whistling Noise
Hey,
I'm new to this forum, so I'm hoping someone can help me out, I've got a 2002 Monte, with 3400 engine, it recently started making a whistling noise. A friend of mine told me that its probably the manifold gasket, but someone else said its the head gasket. Has anyone else here, had this problem?
Old May 25, 2010 | 11:48 PM
Sliver's Avatar
Does the whistling change with engine speed? Are there any CEL's? Notice any missing coolant or anything like that? I've never heard of a whistling head gasket. If the car whistles at idle try to find out what area on the engine it is coming from.
Old May 26, 2010 | 09:06 PM
MrMcknight's Avatar
yeah, it doesnt start until 25mph, and its coming from in between the head and block. I can see a little sepage. It's the color of old antifreeze. What do you think.
Old May 26, 2010 | 11:20 PM
Sliver's Avatar
Wow, could be a head gasket but must be REAL bad to cause a whistle. Best way to rule it out would be to do a compression check on the engine and/or a coolant pressure test. And I take it you are losing coolant?
Old Jul 12, 2016 | 07:55 AM
agent213's Avatar
Can it be mayb the transmission Gasket Seal????
seanpeezy
Mar 21, 2021 01:06 PM
Davon02monte
Jan 31, 2011 04:55 PM
montespython
Aug 28, 2010 03:59 PM
Jack The Ripper
Jun 30, 2010 10:48 PM
ag3nt0r4ng3
Jul 25, 2005 10:56 PM
