whistling 3100 at idle?
Old Aug 26, 2010 | 10:59 PM
montespython's Avatar
Default whistling 3100 at idle?
Hi all, only happens when not on the gas, typically heard at under 25mph. Makes me think of a vacuum link? Oh yea quiets when braking(using vacuum for booster?)???TIA!I checked pcv valve and what not...I do try to keep everything working well too...
Old Aug 26, 2010 | 11:32 PM
nitehawkjcb's Avatar
It probably is a vacuum leak. Start the car, pop the hood and listen to see where the leak is coming from. They're sometimes difficult to find. It might be something as simple as your intake coming loose.
Old Aug 27, 2010 | 08:03 PM
ya know...never thought about the upper plenum? didn't here the stupid thing today while listening for it! I did the headgaskets on it a year ago or so...
Old Aug 27, 2010 | 08:59 PM
Did you replace the upper and lower intake gaskets when you did the head gaskets? I hope you bought all new ones, if not, there's your problem.
Old Aug 28, 2010 | 09:34 AM
Yes, also replaced WP, plugs, filters, ign.wires, fluids,tires,brakes,whl.bearing, fuel tank...what else
Old Aug 28, 2010 | 03:59 PM
Check all your EVAP lines, EGR, throttle body gasket.
seanpeezy
Mar 21, 2021 01:06 PM
MrMcknight
Jul 12, 2016 07:55 AM
Davon02monte
Jan 31, 2011 04:55 PM
Jack The Ripper
Jun 30, 2010 10:48 PM
vita
Oct 15, 2007 08:56 PM
