whistling sound
Old Jun 25, 2010 | 11:58 PM
Jack The Ripper's Avatar
Default whistling sound
Hey guys, i have a 00' Monte Carlo 3.4L V-6. There's a whistling sound like a faint jet engine sound coming from my engine. I hear it when it's both idling and when i'm accelerating. I opened the hood and tried to listen where it's coming from and it sounds like it's coming from inside the engine itself. Any ideas on what this could be? I also recently replaced my radiator, radiator hoses, transmission line and water pump. Could any of these have anything to do with it? Thanks guys.
Old Jun 26, 2010 | 12:01 AM
Could very well be a dead, dried, stuck bug in the opening of the airbox, I had this happen a loooong time ago in a truck I used to drive. Yes, true story.
Old Jun 26, 2010 | 02:25 PM
nitehawkjcb's Avatar
You could have a gasket leaking somewhere. Check your throttle body gasket, upper intake gasket, lower intake gasket, and check the heads for compression.
Old Jun 28, 2010 | 08:31 AM
MAMONTE's Avatar
I would agree with Nitehawkjcb, kinda sounds like it could be a leaking gasket.
Old Jun 28, 2010 | 09:04 AM
x2 on a gasket leak. I would throw some soapy water in places and see if it bubbles from the air escaping.
My car sounded like that when I put my HV Throttle Body on, because I didn't think the gasket needed to be replaced. Took it back off and swapped the gasket and it was fixed
Old Jun 29, 2010 | 01:15 AM
I definitely appreciate ya'lls feedback!! Thank you. Do ya'll think it could be a messed up serpentine belt? because i recently replaced my water pump without taking off the belt like i should have. Could this be contributing to the noise? And also if ya'll dont mind, how and where would i find some of those gaskets to check? Thanks again guys!
Old Jun 29, 2010 | 11:15 AM
Gaskets are where parts meet together, so start there and try to listen for a noise like air escaping.
Or create a watery soapy solution and lightly spray it around to see if it bubbles up (from the air escaping)
Old Jun 30, 2010 | 12:22 AM
LOL make sure its not a dried booger in your nose when you breath before you start throwing money at somthing that can be solved with a quick hobo blow??
Old Jun 30, 2010 | 01:50 AM
Pure2sin's Avatar
Do you have a CAI? lol JK But if you are worried about gaskets I would get a compression test done. Are you having any other symptoms other than just the sound?
Old Jun 30, 2010 | 10:48 PM
I'm not sure but ever since i changed the water pump and put a new radiator in it seems like my car isn't as "speedy" in acceleration as it use to be but i'm not 100% sure. As far as everything else on the car, works fine. It's just that whistling sound. However i noticed that when i'm stopped in one spot with the engine running, and i turn the wheel all the way to the left or all the way to the right, that whistling sound changes it's pitch. That would be something with the power steering system wouldn't it? Thank you guys for all your feedback!
seanpeezy
Mar 21, 2021 01:06 PM
MrMcknight
Jul 12, 2016 07:55 AM
Xavier Willis
Aug 25, 2013 09:15 AM
Davon02monte
Jan 31, 2011 04:55 PM
montespython
Aug 28, 2010 03:59 PM
