MAF sensor modification?
Old Oct 9, 2009 | 11:42 AM
Default MAF sensor modification?
ok, i got the 3400 and was wondering if you can remove that mesh screen inside the MAF sensor. be great if anyone knew
Old Oct 9, 2009 | 11:52 AM
Any reason why you want to do it?
No real gains on those engines for a MAF Descreening.
Old Oct 9, 2009 | 12:15 PM
well i got a chrome pipe coming from the air box to the ground where it goes to a 4" elbow pipe so its kinda half-assed fored induction as i go faster, so i mean what do you think? can it be done and how do you do it, the descreening? also are there any negative affects to doing so?
Old Oct 9, 2009 | 02:00 PM
There's no positives to doing it, so I just wouldn't bother. Save yourself the time and the risk from damaging something.
Your forced induction doesn't sound so great, what are you talking about? / pictures?
Old Oct 9, 2009 | 02:01 PM
Old Oct 9, 2009 | 07:37 PM
Of course you can- take some snips and start cutting just watch out that you don't hit the element.
However, as said above- its a stupid idea, especially if you don't have a pcm tuner. The minimal gain in airflow is just not worth it. Plus, that screen is an air straightener- is the tubing directly in front of the MAF perfectly straight coming in? I doubt it is, you probably have like a 45* elbow, or a filter (if its an external) right before your MAF.
Just leave it in, you'll be much better.
So you have a piece of tube feeding air to the stock airbox? Any pics? Are you running a higher flow filter?
jglancy87
Mar 22, 2011 08:45 AM
Nova1585
15
Oct 11, 2009 04:44 AM
steelmalu43
Aug 8, 2008 04:23 PM
CHOWEE21
Apr 6, 2008 07:26 AM
spills
Dec 30, 2006 09:55 PM
