MAP/MAF Sensor for 3.4 motor
Old Apr 20, 2009 | 06:01 PM
Nova1585's Avatar
Default MAP/MAF Sensor for 3.4 motor
I need help with this, im trying to install a performance module and i cant find the MAP/MAF sensor to hook the wires to...help please
Old Apr 20, 2009 | 08:01 PM
Nova1585's Avatar
the module is the JET v-force module, i cannot find the wire from the map/maf sensor..any input would b great thanks!
Old Apr 20, 2009 | 08:59 PM
kweef's Avatar
um those are 2 different sensors? do u want both locations or what? maf is mass air flow and the map is manifold absolute pressure im thinkin u want maf...
Old Apr 20, 2009 | 09:12 PM
Nova1585's Avatar
yea i know theyre two different ones, i found the mass air flow i cant find the MAP one tho
Old Apr 20, 2009 | 09:14 PM
The Popcorn King's Avatar
if my memory serves me right, you either have one or the other. not both.
Old Apr 20, 2009 | 09:59 PM
kweef's Avatar
only have one? my car has both...i cant say i know for sure but y would a car have one and not the other. one measures the air goin into the engine the other measures the pressure in the crankcase...
Old Apr 21, 2009 | 05:53 AM
Nova1585's Avatar
i meant was i know where the mass air flow sensor is..i dont know where the MAPsensor is because i have to run 2 wires to it
Old Apr 21, 2009 | 06:25 AM
Look 4 something that looks like above
Also, maybe the below links might `help
Good Luck
<LI about="r14">MAF sensor 3.4L help plz [Archive] - Camaro Forums - Chevy ...
The car is designed to work without a MAF, it uses the MAP sensor to control engine management. Cars designed with a MAF also have a MAP sensor, ...
camaroforums.com/forum/archive/index.php/t-23071... - 11k - Similar pages
http://camaroforums.com/forum/archiv...p/t-23071.html
<LI about="r14">
<LI about="r15">Chevrolet Repair: MAP sensor high input, vacuum source, monte ...
Feb 19, 2008 ... i have a 2002 monte carlo LS 3.4L, my "check engine" light came on about a month ago indicating my MAP sensor had a high input. i replaced ...
en.allexperts.com/q/Chevrolet-Repair-808/2008/2/... - 16k - Similar pages
http://en.allexperts.com/q/Chevrolet...high-input.htm
<LI about="r15">
<LI about="r16">ENGINE MANAGEMENT
Thanks Member's for your Help 2 Member: Nova1585
Old Apr 21, 2009 | 04:21 PM
It is possible, and common. The MAF measures the amount of airflow coming in- and fuels according to that.
You could also run a setup with just a MAP- you know engine RPM, the MAP tells you pressure/vacuum in the intake manifold (which tells you how much load the engine is under), and you know the engine's volumetric efficiency at each rpm vs map point (its a table lookup that the engineers program in). So you can also fuel based on that.
I know of a lot of cars that run only a MAP sensor- most of our GM V6's run both a MAP and a MAF though (generally better for us who like to mod and can't tune).
Its not crank pressure necessarily that it is measuring- its pressure/vac in the intake manifold
Old Apr 21, 2009 | 06:43 PM
kweef's Avatar
sry should have said vacuum not pressure. i never thought of it like that...using vacuum to measure air intake instead of the other way around. i always thought of it as a value check and to test the egr... but i suppose u can always just use the vacuum measurement to calculate air flow
