headlight ram air
Old Jan 10, 2008 | 10:49 PM
RickCoMatic's Avatar
Default RE: headlight ram air
Two lift-out plastic catches and the whole headlight assembly just falls right out of the front.
If you are having an issue aiming the headlights ... you can try doing what I did. I Duct-taped a fat fender washer to the front of the headlight mount and it moved-over the beam a few degrees. It's an odd way to adjust the beam ... I know ... but, there isn't a real Left ~ Right adjustment feature. Just an Up ~ Down adjustment. With the washer keeping that whole assembly moved out a bit ... the Beam is more to the Left and that's what I needed.
Old Oct 1, 2008 | 02:08 PM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
so is that what the little screw is for by the headlamps? to move the lowbeam bulb up and down. I just installed new housings and one bulb is aimed really high and the other is really low. so annoying, but cant seem to move the bulbs. if thats what the screw is there for, then im gonna feel really stupid.
Old Oct 10, 2008 | 08:37 PM
04 Intimidator's Avatar
Yes, it is for adjusting the angle of the headlight.
siouxcity04montess
Jun 5, 2010 05:49 PM
kent00SS
Jul 4, 2007 10:41 AM
spills
Dec 13, 2006 12:49 AM
White05LT
Oct 10, 2006 05:51 PM
Mott The Hoople
Jun 22, 2006 04:35 PM
