7th Gen ('06-'07): Cold air question !
Okay guys so im looking for more sound for my 07 SS, and a good intake is where i will probably start but i have a couple of questions after mind boggling on the net. First...
1- Will replacing the stock air box and adding a bigger filter really do so much?
2 - Im cheap and low on money, I know a box is prefered, but is it needed. Granted these engines get hot as...well you know.
3- Whats a good place to start? My buddy has his filter without a box for now in his 07 GXP bonnivile with his 4.6 and it sounds beastly.
4- If i were to build a box, what materials would I use? Or should i just have mike help me make one? ( lol hoping mike sees this as usual)
Or is there anything else I could do for a bit more sound and gain, I prefer MPG vs HP since I have enough HP, granted its a performance car.Sounds backwards I know but lol.
Any help would be needed, and thanks guys
If you're serious, shell out the money for a good intake. If you don't have a box then you just have a hot air intake. The whole.point of the intake is to increase flow and get colder denser air from outside the engine compartment.
Thats what I would assume, so I kinda looked at my dummy friend like uhhh isnt it just sucking up hot air? O.o;....Whats a good material to make a box out of? I see people using sheet metal but again, dummy said it holds too much heat? And do you have any estimate the cost of building one? I might just buy one of bills and stop being cheap, im just curious.
And thanks for your advice.
The colder denser air helps give the engine more power and often times a cai flows much better too. Sound wise, i would say its louder since the intake is more open and flowing. On my car i now hear the supercharger where with the stock setup i couldn't.
dont waste your money on a cold air intake. sound wise its hard to tell a difference from stock. performance wise for the price of either of the 2 big name cai you could get an ls1 intake and most of the needed parts to make it work. i would take the 30-40hp jump of the ls1/6 intake&tune over the 10 of the intake&tune any day. this is unless you build one for cheap or buy one used for a reasonable price.
I was going to build one for cheap, I started testing around with one, without a box. Got my CPU and all out, ughhhhh. I ran outta time yesterday to take measurements to build a heat cover or something, but anyway, I added a spector filter to the connection, removing the old bulky box. But now, my service traction light would pop on and off sometimes. This morning stayed on for maybe 3-5 mins. Car as a tiny bit of jerk, but depends on how I lay my foot down. Could this be due to the CPU kind of expose temporarly or what?
And do we have a exhaust breather tube? For the small filter?
Snyderman
Dec 28, 2011 07:56 PM
siouxcity04montess
Jun 5, 2010 05:49 PM
