Wires through Firewall question
for our cars you don't need to drill a hole because there is already a hole there.
if it was an inexperienced installer they may have drilled a hole, but you can make the 0 ga wire fit through the space where the grommet is.
Well, Ladies and Gents, thanks to my friend kevin (showed me the module) and a huge THANKS to Perry for the wiring diagram, IT ALL WORKS.
ran the wire through the hole that Trewny showed in his video (be careful whith those 2 bolts, i broke one off, have to replace that lil bracket now) i then ran the wires to the under side under the carpet, i then followed a harness going up the dask (around the ebrake pedal) and hooked them to my stock switch..
i still have to pretty it up under the hood, i just wanted to get it all hooked up to see if it'll work.. So once thats done i'll take some pictures and post them!
Killacam
41
12-10-2011 09:17 PM
sumbum06mc
03-14-2008 08:40 PM
