water leak through firewall?
Old Dec 13, 2010 | 07:15 PM
Habbibie's Avatar
Default water leak through firewall?
I've heard that there is a screw somewhere near the cabin air filter that has a gasket around it, and when it breaks or becomes loose it causes water to seek in through the fire wall into the interior and leaves me a decent buddle on the passanger side floor board, now i've heard you can reseal it with epoxy or similar product,
Question is: where is that screw at? can some one snap a pic of it if possible or atleast direct me to a good DIY of how to repair it.
thanks in advance.
Old Dec 14, 2010 | 05:17 PM
nitehawkjcb's Avatar
Do you have a sunroof? If so, that might be your water leak issue. They get clogged up.
If not, I'm calling a bad heater core leaking into your floorboard.
Old Dec 14, 2010 | 06:03 PM
Habbibie's Avatar
yea i do got a sunroof, but how do i un-clog it?
Old Dec 14, 2010 | 06:42 PM
I'm not sure as far as Monte's go, but the drains for some sunroofs are underneath the cowl (plastic piece at the bottom of the windshield). You have to pop the hood, remove the cowl, and the drain's down there AFAIK
Old Dec 14, 2010 | 06:48 PM
In the how-to section, we have how to change the cabin air filter
check that out
Old Dec 14, 2010 | 07:13 PM
sean44998's Avatar
I have the same issue on my 2004 ss. I cleaned the cowl and I still have the leak. I hadn't heard about a screw. This weekend I will put her into the garage and see if I can find it. I will post on Sat or Sunday with the results.
Old Dec 22, 2010 | 06:09 PM
SS2004's Avatar
I had the same problem,& as suggested by a member,checked the weatherstrip under the plastic at the cowl. Sure enough,it had fallen off. Put some silicone or weatherstrip adhesive on it,& put it back on. It should cure your problem.
Old Jan 18, 2011 | 10:05 AM
chamberz's Avatar
Are you speaking about the plastic on the outside at the bottom of the windshield?
Old Jan 30, 2011 | 07:00 PM
SS2004's Avatar
Yes, under the wipers when they are in the park position, on the passengers side. Turn the wipers on, & shut the key off when they are at their highest point on the windshield. Then remove the plastic cowl over the cabin air filter.
Old Jan 30, 2011 | 07:49 PM
baja216's Avatar
Hey guys, I think this is what you're looking for! I had an issue with my '02 where I would get water on the floorboard. I ordered the piece shown here (really cheap from the stealership) and it took about 20 minutes to install. I've had no issues since.
GM part is #15794785 It can be bought at any local gm dealer
http://www.grandprixforums.net/water...-fix-6961.html
