6th Gen ('00-'05): wipers acting up!
Old Aug 6, 2015 | 10:28 PM
claydoh's Avatar
Default wipers acting up!
Hi, my 2003 Monte just started this, wipers work in all speeds etc but when I turn them off they will go across one time then stop straight up in middle of windshield instead of down and "parking" as they should??? any ideas??? aggravating driving in the sunshine with the wipers on lowest intermittent speed!! lol
Old Aug 15, 2015 | 11:51 PM
claydoh's Avatar
really ? no help or ideas people???
Old Aug 16, 2015 | 12:15 AM
Hey hi, found this bit of information. this could be the culprit. Hope this helps get you started on the troubleshooting.
On GM vehicles, this problem is usually caused by a defective park switch in the wiper motor. Inside the motor is a rotating cam that allows the wipers to cycle up to one stroke after the switch is turned off. When the wipers come down to park position, the cam opens a switch called the park switch to stop the cycle.
if the wipers are stopping before cycling down, the park switch is open already, so the motor does not have power to continue downward.
The park switch is an integral part inside the motor assembly. It is not serviceable separately and you cannot purchase just the switch parts anywhere. The standard repair is to replace the wiper motor.
Read more: http://www.justanswer.com/chevy/1a7v...#ixzz3ix5Agzy2
Old Aug 21, 2015 | 12:53 AM
claydoh's Avatar
Thank you Zippy!!
Old Jan 29, 2016 | 02:05 AM
claydoh's Avatar
Ok ! still have a wiper issue! I replaced the wiper motor, kind of a pain in the ***, but before my wipers worked on reg and high, but would park in middle of windshield when turned off! NOW.. they work on reg and high,BUT, on intermittent they stop up then procede down!! most aggravating thing ever as it rains here in Florida all the friggin time!! HELP!!
Old Mar 30, 2019 | 02:09 PM
straffin's Avatar
Originally Posted by claydoh
...on intermittent they stop up then procede down!!
You ever find a fix for this? I have the exact same issue. :-(
- John
Old Apr 5, 2019 | 01:23 AM
claydoh's Avatar
No !! aggravating as sh-t !!
Old Apr 5, 2019 | 05:27 AM
Jeffs02rwdSS's Avatar
I don't know if it would fix your problem but I would be replacing the wiper switch .
mwjames
Dec 25, 2013 08:27 PM
tchudy
Jan 22, 2011 12:21 PM
J M Henn
Jul 27, 2009 06:37 PM
jims875
Feb 5, 2008 07:32 PM
rob559
Feb 22, 2007 11:13 PM
