Turbo, put on hold.
Old Mar 24, 2014 | 04:49 PM
Shelbo Mustang's Avatar
Default Turbo, put on hold.
So I've been going on and on about putting a turbo on the Monte but I have decided not to do it yet. The reason being is the car has 202.593 miles on it. I was going to put it on there anyway and run it till I blew it up.(sounded like fun) Then I got to thinking about it and all the work did not sound like fun!lol So I went and got another motor today. I'm going to rebuild it this summer that way I can still drive the car and push more boost to it when I put it all in this coming up winter. I plan on porting and polishing the heads,intake,and throttle body.
What all would you all do to the motor to make it handle around 20 pounds of boost safely? I plan on driving the car about every day so I need to keep this in mind. I'll be posting pictures as I make progress. This is my first turbo motor so I'll be asking a lot of questions so please bear with me through this build.
Here are the picture's of the beginning of the build.
Started porting and polishing the throttle body.
Old Mar 24, 2014 | 08:48 PM
turbo monte's Avatar
22psi is a crap ton of boost and I would never even think about that on a daily driver. For a daily driver I would stay around 10-12 psi.
To get even close to 20psi you will need a massive fuel system and probably run e85 or race fuel. Also 20psi will make around 550ish hp which will kill a trans very very quickly. 10-12 psi will make around 350whp and is plenty for a daily driver. This will still cause trans issues on a stock trans but a built trans will last a little while. If only making 350whp on 10-12psi no need for heads etc just a very good intercooler, bigger injectors, fuel pump rewire, racetronix 255 fuel pump, and either plogs front and rear for a zzp turbo kit or plog up front and Ported rear on a cartuning kit. Also make sure to have a cutout
Old Mar 24, 2014 | 09:40 PM
I just sent you a pm before I read this,lol After reading a little about your car I realized that 20 is to much. I'm sure that with my work and your knowledge we can get this car built. thanks for the info. again
May 26, 2012 05:46 AM
Tadcaster
Apr 10, 2012 11:31 PM
rj
Oct 19, 2007 09:47 PM
BeachBumMike
Apr 11, 2007 11:29 PM
Bml97MC
Mar 15, 2007 01:36 AM
