torque converter solenoid
Old Jul 2, 2011 | 10:52 AM
basicdumbass's Avatar
Default torque converter solenoid
I have a check engine light and put the reader on the car and it came up with. torque converter soleniod is stuck/off. is this the shift solenoid I keep hearing about ? probably need a new one ,felt the car surging the other day going down the road.
Thanks Brian
Old Jul 2, 2011 | 12:38 PM
nitehawkjcb's Avatar
There are 4 solenoids in the transmission - two shift solenoids, a Torque Converter Clutch solenoid, and a pressure control solenoid. You have to drop the cradle and remove the trans side cover to access the valve body. Might as well replace the TCC and PC solenoids, or even the shift solenoids while you're in there
Old Jul 2, 2011 | 01:30 PM
Is this in a repair manul if I pick one up? and are you able to get these parts at autozone or napa ? Im realy good at turning wrenches so Im sure I can handle it.So pull the axles and drop the cradle is what your saying? the valve body is under that side cover on the left side.is there any kind of shift kit to do wile in there?I hate the slow shifts.
thanks Brian
Old Jul 2, 2011 | 03:35 PM
I'm not sure if it's in a repair manual. It's not in my Haynes manual.
But yes, pull the axles and drop the cradle, you need something to hold the transmission atop the motor as well, Autozone rents them. And I ordered all my solenoids from Autozone. If you want a shift kit, check zzperformance.com or tripleedgeperformance.com, they might have some
Old Jul 3, 2011 | 06:14 AM
Thanks for the imfo.
Brian
Old Jul 4, 2011 | 07:38 PM
well today I was detailing under the hood ,I stop and look at the fuse box. I notice it said trans sol. popped the cover off pulled the 10 amp fuse and it was corroded. cleaned it put a new fuse in and the problem is gone. For now.it was doing a shudder every once in a while starting from a light.now its not doing.Im still figuring it cant be that easy.
Brian
Old Jul 5, 2011 | 01:38 AM
Well, if the fuse was corroded, that could've been giving you your issue the whole time; lucky you! lol
ktagrnma3
Aug 10, 2015 11:41 AM
vicky0598
Feb 18, 2015 10:34 PM
rmorman
Oct 24, 2013 06:32 PM
batman
Jun 29, 2007 06:04 PM
Boost
Mar 28, 2005 01:51 PM
