torque converter
Old Jun 28, 2007 | 12:58 AM
batman's Avatar
Default torque converter
were can i get a torque converter for my 04 LS?
Old Jun 28, 2007 | 06:58 AM
ExplosiveSoundz's Avatar
Default RE: torque converter
You can find a good selection of torque converters here:
http://www.intense-racing.com/Mercha...roduct_Count=4
Old Jun 28, 2007 | 07:13 AM
wiz kidd's Avatar
what happened that you need a torque converter for it already?? usually they're just dealer item's, i couldn't find the acdelco # though
Old Jun 28, 2007 | 12:19 PM
will the link that I gave not work on the LS version? They work great in the SS
Old Jun 29, 2007 | 04:06 PM
batman's Avatar
im just looking to go faster and i heard that getting a torque converter would help, is this true?
Old Jun 29, 2007 | 06:04 PM
GrandPaDave's Avatar
ORIGINAL: batman
An after market torque converter is designed to change your stall rpm's.
Yes this helps you go faster in the 1/4.
But you are better off ifyou have posi or limited slip and sticky tires.
What happens is your standard torque converter on your automatic trans hooks up at about 1k to 1.5k rpms because of the centrifugal clutch.
An after market torque converter can be ordered with a clutch that hooks up at 1.8k, 2k, 2.5k, 3k, 3.5k, 4k or even more rpm's. This allows you to get your engines revs up before launch.
There's tons of info on the web if you google "high stall torque converter."
dtesgue
Jun 1, 2012 06:24 AM
whitemonte
May 28, 2012 10:35 AM
nick_
Nov 27, 2011 02:29 PM
basicdumbass
Jul 5, 2011 01:38 AM
Boost
Mar 28, 2005 01:51 PM
