Torque Converter Disaster!!!
Old Mar 26, 2005 | 04:55 AM
Boost's Avatar
Photobucket
Default Torque Converter Disaster!!!
Well, it all started about 8:30am. I got to school and got rite to workin on getting my converter installed. by 11am it was installed and ran it through the gears on the lift, everything was fine. 12pm i drove it out of the shop and pulled my friends VR-4 in the shop. 12:45pm took out monte onto the road right outside my school. I powerbraked the car and reved it to 2800 RPM, a little under the stall speed. Let off brakes, and little screech and pulled the front wheels about 2" off the ground. then it reved to 5600 RPM a shifted into second. as soon as it hit second, something went completely wrong. The car reved like it was in nutral, and wouldn't shift. I downshifted and nothing. Got to College Dr. and tried Reverse, Still NOTHING. I was like, Holy ****, Did my tranny just take a ****. Me and my friend Grant pushed the car off to the side and looked around the bottom of the car. No Tranny Fluid leaking. about 3pm, i got the car towed back to the school. I talked to my teacher and he said, as soon as i jumped on it, it prolly pulled the Converter out of the Input Shaft. Monday or Tuesday, im gonna bring it back into the shop and try using washers to bring the converter closer to the tranny...
Old Mar 26, 2005 | 09:38 AM
montejass's Avatar
Default RE: Torque Converter Disaster!!!
Man, I hope it didn't do any damage to that new converter..
What kind of HP are you pushing??
TVW
Old Mar 26, 2005 | 11:47 AM
Boost's Avatar
Photobucket
300 to 350hp. if the converter is messed up, ill just call summit and tell them the converter was defective. Plus i had the help of my teacher who is the best transmission builder on the east coast
Old Mar 26, 2005 | 05:26 PM
Patrick's Avatar
do you ahve some suspension work done? the car that i track runs mid to low 12s and i have only gotten the LF tire off the ground once, and even then, its only a hop, with Hoosier QTPs...on a dragstrip....
Old Mar 27, 2005 | 01:55 AM
benhillzone3's Avatar
what are mid to low 12's?
Old Mar 27, 2005 | 10:41 AM
Boost's Avatar
Photobucket
Elapsed Times (ETs) at the Track
Old Mar 28, 2005 | 01:51 PM
Boost's Avatar
Photobucket
I figured out the problem. It is the Converter. The converter will not line up with the splines on the tranny, thats why it keeps messin up. im just gonna throw the old TC in and say screw it...
BeachBumMike
May 15, 2014 07:41 AM
Crusader SS
Mar 23, 2014 08:52 PM
nick_
Nov 27, 2011 02:29 PM
basicdumbass
Jul 5, 2011 01:38 AM
batman
Jun 29, 2007 06:04 PM
