Opinion Needed: Torque Converter solenoid Removal
Old Feb 17, 2015 | 11:09 PM
vicky0598's Avatar
Default Torque Converter solenoid Removal
98 Monte Carlo z34 3.8L How to remove and install a torque converter solenoid. Need some info asap.
Old Feb 18, 2015 | 05:08 AM
Welcome to the forum!!
try these links..hopefully they help
click--> https://montecarloforum.com/forum/ge...olenoid-29322/
click--> How To Replace Your Torque Converter Clutch Solenoid (GM)
Old Feb 18, 2015 | 04:40 PM
turbo monte's Avatar
If I'm not mistaking you need to pull the driver side trans cover off to get to the solenoids as there inside the trans.
Old Feb 18, 2015 | 10:34 PM
nitehawkjcb's Avatar
You have to either lower the engine cradle to get access to the side cover of the transmission (it will be on the driver's side of the car), or pull the entire engine and transmission out to be able to remove the side cover. If you're doing this much, might as well replace the rest of the solenoids while you're in there.
ktagrnma3
Aug 10, 2015 11:41 AM
rmorman
Oct 24, 2013 06:32 PM
basicdumbass
Jul 5, 2011 01:38 AM
batman
Jun 29, 2007 06:04 PM
Boost
Mar 28, 2005 01:51 PM
