Tire chain clearance
Old Jan 2, 2013 | 09:59 PM
qacek's Avatar
Default Tire chain clearance
Hello, I have a 99 Monte Carlo Z34 with 225/60R16 tires. I was looking to get some tire chains but I read in the owner's manual that I shouldn't use tire chains because there isn't enough clearance and they can damage the car.
I looked on Amazon anyway and they said that a number of chains would fit my vehicle. It looked like chains were typically 10mm thick. But I don't know if Amazon is just using my tire size or if it knows something about Monte Carlos that I don't.
Unfortunately I live in an apartment complex so it's a little difficult for me to check the clearance manually, so I was hoping someone here might have had first hand experience with using chains on their Monte.
Old Jan 2, 2013 | 10:11 PM
Mike 00LS's Avatar
Amazon is just showing you chains that fit 16" tires. I'm not sure about a 5th gen because your wheel wells are shaped a bit different.
Having a memory of the chains we used back in the day (granted they were used on a truck) they probably would be grabbing inside the wheel well. So I'm going to say the owners manual is probably correct that our cars can't take them.
Personally I have no need for chains as we normally don't exceed 6 inches a night, and we'll have it plowed before the next night piles up again. So I can't speak from experience.
Old Jan 2, 2013 | 10:28 PM
turbo monte's Avatar
thinking/trying to put tire chains on a monte makes me cry
Old Jan 2, 2013 | 10:43 PM
jimbo7's Avatar
This sounds like a horrible idea. Get some steelies and put some snow tires on em.
Where do you live that you think you need chains, Alaska?
Old Jan 2, 2013 | 11:15 PM
zzapultimate's Avatar
Snow tires sounds like a much better idea.
Old Jan 2, 2013 | 11:24 PM
qacek's Avatar
Thanks for the quick responses. I recently moved to California and they'll put chain controls on roads in the mountains sometimes. I'd rather not use chains at all but I would still like to go skiing. This is my only vehicle so I was hoping it would be possible. Snow tires apparently don't cut it unless you have 4WD.
Old Jan 3, 2013 | 01:47 AM
You also need to look at the clearance of the strut tower above your tires. On my 6th gen, I can barely fit my fingers between the tire and the bottom of the strut tower.
Old Jan 3, 2013 | 06:08 AM
If the locations you travel don't plow/salt the road ways, then those are NOT locations for a car. You should consider a 4x4, 4WD or AWD vehicle.
I live in an area known for getting blasted by winter snow, drive a FWD car with good all season tires. That's usually plenty. I know one or two guys that live around here and use snow tires in the winter and rave about how good they are.
Old Jan 3, 2013 | 07:05 AM
03SSLE's Avatar
When they say not to use chains I think they are referring to (old school) traction devices that are literally made out of chain. Last Winter when we had some ice and snow on the roads I test fit my cable chains and drove the car a couple of miles. No problems whatsoever with clearance. I'm running 225/55R17 tires. Larger sizes will have less clearance. The main cause of damage from chains is improper installation.
Jul 2, 2012 09:03 AM
TheMonteCarloKid
Feb 6, 2010 04:11 PM
joemccall86
Dec 12, 2007 04:45 PM
scc24540
Dec 1, 2007 06:28 PM
jaws7647
Oct 26, 2007 09:04 PM
