Rear clearance
Old Sep 23, 2007 | 07:14 PM
jaws7647's Avatar
Default Rear clearance
Hi. I have a 2001 Monte Carlo that I reccently put 18 inch rims on. Tires size 235 - 50. When People sit in the back seat some times I have a problem with it hitting. I was wondering if any one had any suggestions to correct this problem?
Old Sep 23, 2007 | 07:21 PM
ExplosiveSoundz's Avatar
Default RE: Rear clearance
Well, there are three fixes:
1) Don't put people in the back seat?
2) Go with an even MORE lo-pro tire
3) Get stiffer aftermarket shocks and springs.
Old Sep 23, 2007 | 09:35 PM
04 Intimidator's Avatar
4th option is put the old 16's back on.
Your best bet would be to put in stiffer aftermarket springs and shocks. This is just one of those necessary expences that you need to do when you buy larger rims that most people don't consider.
You can't just slap on larger rims, you have to upgrade the suspention as well or it rides like ****.
Old Sep 24, 2007 | 04:42 PM
MonteBoosto's Avatar
I agree, upgrading your suspension would be best. If you don't have the cash you can cheat though. When I put my 20's on I modified the lip underneath the back fender where the tires hit when you have weightor hit big bumps. You can't cut long ways because of the tack welds but you can make half inch cuts every half inch on the lip and bend them up flush with the fender and undercoat the finished product. You can't see anything from the outside and it can be done clean if you take your time. (I can feel all you cringing at this procedure)..lol.. but it cost about 20 bucks and I haven't had a problem. The key is to undercoat when your done to prevent rust and such and try not to cut any tack welds.
Old Sep 24, 2007 | 05:22 PM
GrandPaDave's Avatar
ORIGINAL: MonteBoosto
LOL! This method is so extremely old school. We all did this when we put L-60's and airshocks on our muscle cars.
Old Sep 24, 2007 | 09:14 PM
jaws7647's Avatar
Thanks for the feedback. Im not sure how i feel about making cutts under the fender. lol. I think Ill go with the suspension upgrade.
Old Sep 24, 2007 | 10:23 PM
ORIGINAL: jaws7647
I think this is the better option as you are fixing the problem rather than putting duct tape on it. Don't get me wrong the cutting method is a good inexpensive way of doing it and saving a good deal of money, but ask yourself what the Pros would do?
Old Sep 25, 2007 | 09:36 AM
jaws7647's Avatar
Do you guys think a set ofKYB AGX Sport Adjustable Struts would be a good fix?
Old Sep 25, 2007 | 09:41 AM
Most certainly! Those are regarded by most Wbody enthusiasts to be in a league of their own. I personally am saving for those right now, along with the Eibach Lowering springs... and for your application.. I think those would be an incredible upgrade! Set to ultra stiff in the rear, and you shouldn't have any more issues with those rims rubbing the wheel well.
-Keegan
Old Sep 25, 2007 | 10:06 AM
jaws7647's Avatar
Thanks for the input. Do you thinkI could get away with just replacing the rear or should I do all 4?
