Fourth Gen SS, Starter/Header clearance
Old Feb 5, 2010 | 10:54 PM
TheMonteCarloKid's Avatar
Default Fourth Gen SS, Starter/Header clearance
On my 84 ss i just installed new headers, i had to take the starter off the finangle the damn things into posistion and now i've got them all bolted on. the problem is that now the headers are in the way and i cant get the starter installed.... any tips on what i should do. BTW i cant cut the headers to re-shape or re-route them.
I'll take a couple pics of the problem in a little bit
Old Feb 6, 2010 | 12:49 AM
CMC's Avatar
CMC
Until I see pics all I can think of is too unbolt the engine mounts, loosen the trans mount and raise the engine a little until you have enough clearance to get the header on with the starter still bolted on. YOu should be able to move the engine up an inch or so without having to unbolt or remove anything else as long as you are careful and pay attention.
Then again that may be too much and going about it the hard way.
Old Feb 6, 2010 | 01:11 AM
thanks man, i'm going to try and loosen the bolts on the header for a little wiggle room. if that doesnt work i'll try your suggestion. and if neither work i'll post some pics.
and a little extra info incase someone else had this problem with the exact setup, i'm using a set of FLOWtech G-body headers and i have a 350/TH350 swap in the car
Old Feb 6, 2010 | 01:51 AM
thanks for the advice, turns out loosening the header bolts gave me just enough room to get the starter into place and get the bolts in. so after plenty of contemplation, and a busted knuckle. MISSION ACCOMPLISHED
Old Feb 6, 2010 | 04:11 PM
CMC's Avatar
CMC
Cool, man, glad you got it worked out.
matrx10503
Dec 6, 2011 11:11 PM
matrx10503
Nov 29, 2011 12:51 PM
matrx10503
RWD Tech Guides '70-'88
Oct 27, 2011 02:27 PM
Thunder_Horse`79
Aug 22, 2010 01:57 PM
Buknasty
Aug 3, 2010 10:11 AM
