removing cigarette lighter
Old Mar 6, 2012 | 10:45 PM
Larrysmonte's Avatar
Default removing cigarette lighter
Ok I want to move a good 12volt lighter from one center console to another. How do you remove the lighter from the center console? I have the consoles out and have access from the back side.
Old Mar 6, 2012 | 10:53 PM
It threads on in two pieces. One from the front one from the back.
Old Mar 6, 2012 | 10:55 PM
The older ones seemed to, but the one in the 2004 just doesn't look like that. I will check again.
Old Mar 6, 2012 | 11:07 PM
I just went outside to check. If you look down inside the lighter it has a metal tab on each side. I think you just have to push them in from the back. I tried to get a pic but it wouldn't turn out.
Old Mar 6, 2012 | 11:47 PM
Good insight. I went inside the cigarette lighter and pushed the 2 little black tabs outward and slid the metal sleave out of the plastic case housing toward the front. After that the housing came right out. Thanks
Old Mar 7, 2012 | 12:07 AM
Glad i could help.
Rocksteady
Dec 2, 2010 11:37 PM
neneb99
Jan 29, 2009 04:47 PM
Endo
Jan 25, 2008 12:49 PM
benhillzone3
Feb 23, 2007 01:42 PM
ddschneider1972
Jan 7, 2007 11:12 AM
