No power please help
Old 07-05-2013 | 05:26 PM
allen12's Avatar
Default No power please help
My 2001 monte carlo ss 3,8 I can't get it to rev up it wants to bog down on me when i try and rev it up it has been getting worse can't even drive it any more no power anymore i change MAF sensor didn't help
Old 07-05-2013 | 11:54 PM
Does it have a factory cat??? The 2000 and 2001 Montes got a bad batch of cats from GM (GM extended the warranty, but it's been expired for a while now). If it's still the factory cat, I would definitely start there and have that looked at.
Old 07-06-2013 | 12:06 PM
Mike6208's Avatar
you can remove the 02 sensor from the cat near the engine and see if the power comes back, if it does, then bad cat.
Old 07-07-2013 | 08:02 AM
RocknSS04's Avatar
Yes, it's pretty obvious, you have a clogged catalytic convertor.
Old 07-09-2013 | 10:13 AM
allen12's Avatar
thanks for the advice.i was thinking maybe it was the catalytic converter myself.i have orderd a new magnaflow direct fit converter.anybody have any tips or tricks on removing the old converter?
Old 07-09-2013 | 11:09 AM
03SSLE's Avatar
Soak the bolts with PB Blaster the night before, and again a couple of hours prior to doing the job. Clean any residual debris from the exhaust manifold and resonator flanges to prevent leaks. It is easier to remove the O2 sensor once the downpipe is removed rather then trying to remove it still on car. Reinstall in new downpipe prior to installing it on car. Optional - Replace the original bolts with stainless steel.
Old 07-14-2013 | 09:08 AM
allen12's Avatar
it was a clogged cat.runs perfect nowso glad that i found this site.thanks again for all the help
chevyONmine
08-01-2023 08:33 AM
Josh_NGR
03-21-2012 09:56 PM
77gp
01-07-2012 03:04 PM
Emnasty600
07-08-2011 08:17 PM
SamanthaF
11-16-2010 10:41 PM
