fuel gauge wonky
Old Jul 10, 2013 | 06:19 PM
Video's Avatar
Default fuel gauge wonky
my fuel gauge doesnt work. It sticks at FULL and every once in a blue moon itll move around then shoot back to FULL...and i most certainly dont have that much gas in. Luckily though the low gas light still comes on to warn me.
I assume id have to drop the gas tank and replace the fuel pump or something on it to fix this issue right?
Old Jul 10, 2013 | 06:21 PM
My 04 did that had to get a float inside the fuel tank replaced
Old Jul 10, 2013 | 06:22 PM
It's called the fuel level sensor and there is an easy access door in the trunk. Not a bad job.
Old Jul 10, 2013 | 06:24 PM
Video's Avatar
Sweet! Got any pics for me? I could probably also go on alldata at my work and look at how.
Old Jul 11, 2013 | 12:18 AM
nitehawkjcb's Avatar
Very easy if you have an access hatch...
The lever is either sticking at full or the fuel tank level sensor took a dump.
Old Jul 11, 2013 | 07:44 AM
steelmalu43's Avatar
I would have to believe that the level sensor is faulty.
If you can give me your vin I could get you the GM part number
Old Jul 11, 2013 | 09:39 AM
Remind me later and I can try to look it up in my shop books... but alldata would probably have the same info.
Old Jul 14, 2013 | 04:38 PM
Video's Avatar
Alright SES is telling me i need a fuel level sensor now, so thats definitely the problem but that means i have to replace it to pass inspection.
Now you guys say trap door...i remembr with my camaro you had to cut out a square, or is there an actual trap door already there?
Old Jul 14, 2013 | 08:21 PM
RocknSS04's Avatar
The REAL problem is the gas level sensor is dirty/corroded, I'm assuming. I've had that happen. Where are you buying your gas? I switched to top tier gas and the problem went away. Never did change the level sensor out. Haven't bought junk gas since!
mchugh2001
Jan 28, 2015 11:50 AM
S.O.G.
Nov 26, 2014 09:10 PM
robknight13607
Mar 20, 2013 09:14 AM
01 Monte SS
14
Jan 21, 2013 11:57 AM
04chevyboy
Jan 29, 2012 09:50 PM
