Key Fob not working?
Hey in my 2003 LS my key fob just stopped working. Was the factory fob and was working this morning but was not working when I got to work? Tried a different 3 volt battery, does the CR2032 number matter or will any 3 volt battery work? Anything else to troubleshoot? thanks
Same thing happened to me right after I bought my car. What I discovered was one of the solder spots holding the silver... "battery holder", lack of better term, on mine broke loose. I was afraid of trying to re-solder it so I took a small piece of cardboard and put it inside the cover behind the battery, it's worked fine since. I know cheap and bad repair but better the toasting the board since I only have one remote.
Hope it's your problem too and you have more cajones then me to fix it properly and if you don't at least you have a viable option.
Hi Kicker,
Try what
Brian ~> Member JAFO posted.
If that doesn't work ? Check out the below link
http://www.fixya.com/cars/t1879124-r...ry_not_working
If that doesn't work ? Check back on your thread
and hopefully one of our talented tech member's
will help...
Good Luck
Try what
will help...
Good Luck
