Key Fob not working?
Old Jan 16, 2010 | 09:01 PM
kicker's Avatar
Default Key Fob not working?
Hey in my 2003 LS my key fob just stopped working. Was the factory fob and was working this morning but was not working when I got to work? Tried a different 3 volt battery, does the CR2032 number matter or will any 3 volt battery work? Anything else to troubleshoot? thanks
Old Jan 17, 2010 | 07:42 AM
JAFO's Avatar
Same thing happened to me right after I bought my car. What I discovered was one of the solder spots holding the silver... "battery holder", lack of better term, on mine broke loose. I was afraid of trying to re-solder it so I took a small piece of cardboard and put it inside the cover behind the battery, it's worked fine since. I know cheap and bad repair but better the toasting the board since I only have one remote.
Hope it's your problem too and you have more cajones then me to fix it properly and if you don't at least you have a viable option.
Old Jan 17, 2010 | 07:46 AM
Hi Kicker,
Try what
Brian ~> Member JAFO posted.
If that doesn't work ? Check out the below link
http://www.fixya.com/cars/t1879124-r...ry_not_working
If that doesn't work ? Check back on your thread
and hopefully one of our talented tech member's
will help...
Good Luck
buddha112572
Aug 9, 2022 11:49 AM
RocknSS04
Jul 14, 2010 08:22 PM
tloughrin
Oct 28, 2009 02:40 PM
Datafive0
Mar 12, 2007 02:29 PM
03SSdriver
Sep 16, 2005 10:43 AM
