Horn keeps blowing fuse. Any Ideas?
Old Sep 17, 2010 | 07:41 PM
matrx10503's Avatar
Default Horn keeps blowing fuse. Any Ideas?
Ok....I recently had to pull my steering wheel. Put everything bacc and horn worked fine.
Now recently (no changes, no wires re-done nothing) everytime I blow the horn it blow a fuse
The interior lights all shut off and radio shuts off.
Its the "Courtesy CLK" fuse that blows.....the only one that blows
So now I can't blow my horn.......just started all of a sudden
I just pulled the steering wheel AGAIN!!! only to remember that after I put the steering wheel bacc together the first time, the horn was working fine....so I don't think that cause of the problem
Sigh....my Monte is so touch-n-go :-((
Old Sep 17, 2010 | 11:56 PM
stop honking if your horny! just kidding!
um, i would try a bigger amp fuse, or check again to make sure no wires are shorted behind the steering wheel, and go from there
Old Sep 18, 2010 | 06:13 AM
The horn shares a circuit with the cigarette lighter and interior lights. The cigarette lighter is a common cause of a short and thus will also short out the other devices. So, if it is a shared circuit, by process of elimination(disconnecting each device one-by-on) the short should be located and that device replaced. Also check horn relay.....Good Luck
Old Sep 18, 2010 | 12:09 PM
GrandPaDave's Avatar
Yeah, I kept blowing my horn fuse on my Caddy only to find out that there was a penny stuck in my cigarette lighter.
Old Sep 18, 2010 | 12:40 PM
matrx10503's Avatar
I started doing process of elimination before I pulled the steering.
But I just decided to put my steering wheel bacc on, didn't change anything different....and as I said TOUCH-N-GO....nd what do ya know? the horn is working again
Which means.......it will probably stop working again, so I will reference this post again probably
Noonkid
Jul 16, 2012 11:53 AM
SoCal01Monte
Jun 25, 2012 10:30 AM
tommy carlo
Jul 7, 2010 10:19 PM
bbrewbaker
Mar 2, 2009 07:59 AM
White05LT
Oct 18, 2008 11:46 PM
