fuel injectors: clean or replace?
Old May 4, 2006 | 03:57 PM
malletboy's Avatar
Default fuel injectors: clean or replace?
how would bad injectors make your car run in cotrast to just dirty injectors? whats the big difference?
Old May 20, 2006 | 10:30 AM
toeknee94's Avatar
Default RE: fuel injectors: clean or replace?
Most of the time when an injector fails it hangs open or fully closed. If it is stuck open, then i might be hard to start after sitting, when started the cylinder will be dead because of the excessive amout of fuel in cyclinder. A fully closed injector will not allow fuel to flow threw the injector causing a dead cylinder. If you have a dirty injector most of the time you will feel it at idle. Your fuel is not being atomized corrrectly and you can feel a rough idle.
Chris s
Jan 29, 2013 11:11 AM
wtxbear
Aug 28, 2012 09:23 AM
malletboy
Oct 9, 2010 12:13 PM
jgargano03
May 15, 2009 09:56 PM
Nasal
Sep 23, 2006 11:58 AM
