6th Gen ('00-'05): Car shouts off
Old May 8, 2024 | 08:20 AM
Montrcarlo85's Avatar
Default Car shouts off
engine shout off when I put it in drive and give it gas but will drive in the other gears 03 Chevrolet Monte Carlo SS
Old May 10, 2024 | 08:30 AM
Two questions:
-when you say other gears, do you mean if you put it in 1/2/3, it drives fine, but in D it dies?
-does it only happen when you press the gas? What if you just let it idle up to speed before applying throttle?
The gear shouldn't be able to kill the engine - due to the torque converter, the engine can idle even with a fully stopped input shaft, so any rotation on the input shaft should be easier on the engine. Unless its trying to lock the converter by mistake or the engine has other issues.
ThatLFXmonteSS
Jan 24, 2023 12:15 AM
Bigrock313
Dec 15, 2021 10:15 PM
MonteMadness
13
Mar 27, 2012 06:46 PM
bigDog1949
Oct 27, 2009 06:28 PM
1995_corvette
Dec 1, 2007 12:46 PM
