6th Gen ('00-'05): Battery Warning!
Old Dec 11, 2013 | 11:55 AM
Monroe's Avatar
Monte of the Month -- December 2013
Default Battery Warning!
Ever since we got our first real snow fall and temp. fall here in Iowa, my Monte has been having this problem. I'll get in my car, turn it to the ON position...when I do this, my Battery Guage will go from half way and drop to just above the red. Also, the battery light comes on in the message center. However, She will still start everytime, only occasionally it will hesitate slightly. The battery is 1 year old as of this winter. Also, my car sits in an insulated garage every night, so I don't know if it has anything to do with the temp. or if that battery just needs a good charge? My old battery charger got left at the old house when I moved so I haven't been able to test that theory Any theories?
Old Dec 11, 2013 | 02:52 PM
turbo monte's Avatar
have the battery tested to start.
Old Dec 11, 2013 | 04:50 PM
X2 Have the battery tested... We had some at work with a bad cell after six months..
Old Dec 11, 2013 | 05:00 PM
Check connections for corrosion as well.
Old Dec 12, 2013 | 07:41 AM
Do you have a way to monitor the voltage (accurately) while the car is running?
I wonder if the alternator isn't as high as it should be.
Old Dec 12, 2013 | 08:08 AM
owens91's Avatar
Ive been havin this same problem. I sometines get the battery light when I'm driving. It could be becayse I ha e the heat, both seat warmers and rear defogger on at the sane tine but idk. I got the battery when I got the car. So I think this weekend imma ha e it checked and charged. I was starting to look at the altenator because that looks old
Old Dec 12, 2013 | 08:52 AM
Monroe's Avatar
I'll have it tested this weekend, hopefully if its bad i'm under warranty!
Old Dec 14, 2013 | 10:09 AM
Monteman24's Avatar
My monte has done that for... As long as I can remember I guess..
cnogood
Sep 20, 2014 04:16 PM
BeachBumMike
Apr 29, 2014 08:27 AM
70monte1
Jun 14, 2012 05:12 AM
DCfla
Aug 20, 2009 01:26 AM
montejass
Mar 29, 2005 01:16 PM
