Another dumb question from Pizzarrhea.
Old Jan 6, 2010 | 01:59 PM
well thats good to know where that is lol, GM likes to put stuff in strange places
Old Jan 6, 2010 | 02:15 PM
Cowboy6622's Avatar
Need a nice, long funnel to reach that!!!
Old Jan 6, 2010 | 03:29 PM
pizzarrhea's Avatar
I went to another garage and he said it doesn't sound like the rack & pinion is the problem, a friend from UTI said it sounds like the brakes. This is too much haha, I'm bringing it to a garage tomorrow for a test drive so they can figure it out.
Old Jan 6, 2010 | 03:34 PM
Check your fluidssssssss Brake and PS
Old Jan 6, 2010 | 04:16 PM
SpinEm_90's Avatar
rack and pinion? i should have thought of that! we here at the shop were dealing with a couple of cars with that problem yesterday lol epic failure! but yeah power steering wayyyyy down there. It's hella hard for me to reach. But yeah just check your fluids and hopefully you will find the problem
Old Jan 8, 2010 | 11:12 PM
pizzarrhea's Avatar
So, it was the power steering pump. Win!
Old Jan 9, 2010 | 08:30 AM
RocknSS04's Avatar
The steering being tight was the power steering pump, but the 1st thing you posted wasn't about the steering, it was about the ABS lights. That's a different problem all together, and that probably wasn't resolved, and you WILL have it happen again.
The problem there is that when you do a HARD turn the wheel speed sensor wiring from the hub pulls on the connector attached it, and there is a slight amount of corrosion in the connection. You need to take the connection apart and put it back together a few times to clean the connections, blow it all out good, maybe even use some contact cleaner on it. Then spray a little WD-40 on everything but the metal connectors and put it back together, The WD-40 will help absorb the moisture and keep the connector sealed. You might have to do this about once a year. I do.
When the ABS lights go on again, you know what to do.
Glad you got your power steering fixed.
labnjab
Oct 13, 2010 08:55 AM
2004 ss
Oct 17, 2009 05:46 PM
Blown04SS
Dec 13, 2008 03:25 PM
JDub1983
Nov 17, 2008 06:32 PM
06LT3
Jun 12, 2007 04:56 AM
