Dumb Question
Old Oct 11, 2010 | 06:25 AM
labnjab's Avatar
Default Dumb Question
Whats the fuel tank capacity of my monte? I don't have the factory manual so I don't really know. I had a close call late Friday night. I went to a concert that was about 70 miles away in lowell Mass. Had just under half a tank and forgot to fill up on the way down. Decided I would fill up once I crossed back into new hampshire to avoid the high gas prices in Mass. Halfway back the gas light came on at around midnight and it took 20 miles before I found an open gas station. I found one by sh*t luck and took 16 gallons. This is the 1st time I've run it low, usually I fill it up at half but I'm curious as to how big the tank is for future referance.
Now I need to burn all this lousy cumby's gas, lol. Dale's used to shell v-power
Old Oct 11, 2010 | 06:26 AM
It should hold 17 gallons. Far from a "dumb" question
Old Oct 11, 2010 | 06:32 AM
labnjab's Avatar
wow so I was cutting it close, I had another 40 miles to get home when I filled up so I would have run out 10 miles short. i was nervous. I kept telling tom tom to find the nearest gas station and every single one was closed. We must have tried 7 or 8. Finally I programed the gps to go home so I could get back to the highway and try the next few exits up. I rounded the 1st corner and found an open cumbys.
Old Oct 11, 2010 | 06:11 PM
Jomao_o's Avatar
My Dale also loves the V-Power, it's pricey though.
Old Oct 11, 2010 | 07:24 PM
I only use Ultra94. Sunoco is the official fuel of Nascar, but I'm pretty sure that isn't Ultra94 those guys are using...
Old Oct 13, 2010 | 06:14 AM
labnjab's Avatar
Vpower here is actually no different in price then high test at other stores. No its 2.90 ish a gallon. Shell is also the only place around here that sells top tier fuel which is another reason I use them
Old Oct 13, 2010 | 07:54 AM
MAMONTE's Avatar
The actual capacity as listed in the owners manual is 17.5 Gallons.
I have on many many occasions pulled up to a gas pump, filled up (and topped off) and had it take 18.1 or even 18.3 gallons. So I think its safe to say it is an 18 gallon tank if you top it off. (which I know you're not supposed to do, lol)
Old Oct 13, 2010 | 08:55 AM
Nocturnx's Avatar
I always keep my tank empty and drive around with the fuel light on. It keeps my car lighter so I can race mustangs from the lights and win. It's worth like 20HP!
pizzarrhea
Jan 9, 2010 08:30 AM
2004 ss
Oct 17, 2009 05:46 PM
Blown04SS
Dec 13, 2008 03:25 PM
JDub1983
Nov 17, 2008 06:32 PM
06LT3
Jun 12, 2007 04:56 AM
