ZZP ER rockers
Old Mar 13, 2014 | 10:21 AM
I can attest to similar results as Chibi.
I had a ZZP 2.5" DP and high flow cat as well as L67 coils before I did my ER Rockers.
When I did my ER Rockers, they were done at the same time as:
- HV3
- PLOG
- Port Matched LIM
- Ported L67 Throttle Body
- PCMforLess.com tune
And for looks, F-body 3800 aluminum valve covers.
It made a difference! It did not make a "beast", but it improved the 3800 potential a lot. I hope to re-tune the car this summer, as that will make a bigger impact.
Old Mar 13, 2014 | 10:40 AM
Crusader SS's Avatar
Thanks for the input Jason & Mike. I am looking forward to the gains, lord knows we need every hp available to wake these power plants up. You both mentioned a tune, from what I have read, they did not mention having to retune the PCM. I already have in car tune from Will. Do I need to tweek that tune? I will eventually also be installing an HV3. Thanks for your help, it is always appreciated.
Old Mar 13, 2014 | 12:04 PM
The primary reason I got a tune was all my reading said the port matched L67 tb needed different MAF tables put in.
Otherwise, you could run your current tune, but for obvious reasons, re-tuning to match all your mods gives you the best gains. I hope to re-tune my Monte this year myself (instead of a mail order tune).
Old Mar 13, 2014 | 03:26 PM
No need to retune unless you swap the springs and can rev past 5900.
Shoot Will an email, but you'll probably be fine. He might be able to add a degree of timing, but he might say it's not worth it.
Old Mar 13, 2014 | 11:43 PM
Thanks Jason. Makes perfect sense. I understand now.
Old Mar 13, 2014 | 11:46 PM
When Will did my in-car tune, he did advance the timing 3 degrees and I have run high octane, which is fine. So I should be good to go for now. But I will shoot him an email just to be sure. Thanks Mike,
Old Mar 25, 2014 | 08:07 PM
Well, finally got them on today...... Definately a butt dyno increase in HP above 3000rpm...... Very rainy here today so the testing was quite limited... I also had my L67 coils installed at the same time... Loving the results...... Only issue is that it feels like I am getting an intermitant miss, worse when installed and less the longer I drive... Question, is it possible the PCM needs time to relearn new set-up? If not, I will start looking for a faulty coil... Any help would be appreciated...
zipper
Jun 1, 2015 07:50 AM
rglecoff
May 4, 2015 09:48 AM
jd1101
Mar 11, 2012 01:10 PM
04superjr
Jan 23, 2009 04:08 PM
