wiring help
Old Apr 14, 2013 | 05:12 PM
Gib DTD's Avatar
Default wiring help
Its been a while since I've really been active on here, largely because my Monte had caught fire and was totaled. Since then I have purchased another Monte...an '02 White SS limited edition. There were a few minor problems which have mostly been dealt with and now there's only one left to address before I can get it inspected...p0412. I tracked down the problem and its a broken wire at the connector. Anybody have any ideas how ti fix he remove the terminal from the connector to make the repair? (Pics to come in the next post)
Attached Thumbnails wiring help-2013-04-14_18-14-44_19.jpg   wiring help-2013-04-14_18-14-36_581.jpg   wiring help-2013-04-14_18-14-22_676.jpg
Old Apr 14, 2013 | 07:26 PM
z34phoenix's Avatar
go to the junk yard and get a new connector and solder the new one in and shrink wrap the wires. it may be possible to remove the pin inside that connector but its not likely. just replace the connector
Old Apr 14, 2013 | 10:44 PM
Auto zone sells replacement connectors. If its broke anyway just cut it off,take it in and match it up.
Old Apr 15, 2013 | 08:12 PM
turbo monte's Avatar
i agree with junk yard and soldering a new one in and shrink wrapping it. what is that connector for?
Old Apr 15, 2013 | 08:49 PM
Gib DTD's Avatar
It took about 45 minutes to figure out what the switch was called so I could replace it after braking off the male vacuum ports. It controls thefresh air flow to the exhaust to get a more complete burn. The solenoid sits on the metal bracket that sticks above the backside of the motor.
Old Apr 15, 2013 | 09:49 PM
So your talking about the egr?
Old Apr 15, 2013 | 10:05 PM
Gib DTD's Avatar
I found it on the auto zone app, they call it a vacuum canister vent solenoid connector.
red04montels
Sep 21, 2009 04:13 PM
emolineaux
Nov 2, 2008 08:02 PM
mrl390
Mar 3, 2008 03:19 PM
Monte_04
Aug 14, 2007 07:44 PM
Puppet Master
Aug 15, 2006 07:44 PM
