Need some help with some wiring in my 2002 Monte.
Old Aug 13, 2006 | 08:31 PM
Puppet Master's Avatar
Default Need some help with some wiring in my 2002 Monte.
I have a 2002 Monte Carlo LS. I am replacing my trunk light with some neon tubes, and I need to know which of the two wires that hooks up to the trunk light is power, and which one is ground. I am just going to splice into them and completely get rid of the trunk light. Or if anyone could point it out to me on a wiring diagram or something, that would be great. Oh, by the way, hi, i'm new here.
Old Aug 13, 2006 | 09:39 PM
DESS03's Avatar
Default RE: Need some help with some wiring in my 2002 Monte.
best thing use a test light
Old Aug 13, 2006 | 11:03 PM
I have a thing for testing which wire is power and ground I think. You hook the red to the power and the black to the ground, if it is right the meter on it goes crazy. Could I use that? Also, should I disconnect the battery AFTER or BEFORE I check this?
Old Aug 14, 2006 | 12:37 AM
DESS03's Avatar
after u test it if not you wont get a reading and what you are talking about is called a multimeter
Old Aug 15, 2006 | 07:44 PM
mickey's Avatar
ok the easy way to do this is. take the plug off the trunk light. use a test light Ground the wire to the car some place to make sure it is a good ground. then touch the other end to the wires and see if the light in the test light lights up If it dose you have pwoer there. If it dose not then you have a ground and make sure you dubbel check this by checking the light off the bat befor eyou use it and also check the wires twice to be sure.
one other thing you will have to worry about in this is how to get them to turn on and off as the stock light as a mercury switch in them (something close to it) so it knows when to turn on and off due to its angel or position at any given time. Other wise you have created a big draw on the bat. at all times with the lights on all of the time
You could look in to a pin switch to place some where out of sight and out of mind so it will cure this for you and also make it easier for you
paddock
Apr 23, 2019 11:04 PM
ianbmxr
Jan 26, 2010 08:37 AM
PuppetMaster
May 26, 2007 01:25 PM
mickey
Aug 23, 2006 05:31 PM
